Resolved 95 Eclipse RS over heating?
OBie20
Aug 11, 2005
Boston, Massachusetts
I have an eclipse 95 rs and a funny thing happened to me today...i was on the high and noticed my temp gauge going up when i was braking and when i would let off the brake it would go back down.. when i leave the engine at idle the gauge goes a little but above halfway..not sure if it a broken gauge or bad sensor...has anyone had this happen to them?
checked all hoses for leaks and fan comes on...i have no clue why the gauge would almost redline when i brake
Solution
thanks i changed the thermostat and then noticed something thr ground for my stereo system had come loose....i hooked it back up to the terminal and it solved the temp gauge problem.
You might want to delete one of these posts. Either this one or the one in the Newbie Section. You only need one post per problem. Otherwise you'll just get them locked.
Solution
