95 2g head on 6bolt
kubix
Dec 14, 2002
Alright guys ive been reading around the 1gin2g info but I have two questions.
1. To mate the 2g head to the 6bolt, is it a direct drop in or are their any modifications that need to be done?
2. I have a 1g CAS and im going to the buy the RRE wiring harness for it, but how do i install the CAS on my 95 2g head, im really confused.
Almost done with my 6bolt drop in and im confused about this :|
u have the drill out the holes for the head bolts becasue the 1g ones are larger, the cas will bolt up fine and your prob goin to wanna use a 2g intake manifold cuz a 1g intake will b to large for the 2g ports.
do you know the specifications of how much you have to drill out? i need to know so i could tell my machinist :)
Also, im sticking with the 2g head because i believe it can make more horsepower then the 1g but not in stock form of course :)
if using 6 bolt arp head studs you must machine the holes from 11mm to 12mm. The machinist might ask you to bring in the arp headstuds.
Thank you :)
This is true. Not many people are keen on this fact. ;)
But are you using it to its full potential or is it down the road?
A 1G head can be had for CHEAP, and if you are going to take a long time to save the money for the PROPER machining, go for a 1G and sell it later. :thumb:
