Bought a 6bolt Head for my 2g, questions...
my_gst95
569
10
Nov 13, 2002
Sacramento, California
I got a sweet deal on a 6bolt 1g head and it came with the intake manifold. Here's my questions:
1. Can I re-use the 6bolt 10mm hex head bolts since they are reusable, unlike the 2g torque-to-yeild head bolts?
2. I want to use the 1g CAS, by wiring both my cam and crank sensor wires to the 1g CAS, can i remove the sensor and sensor-plate on the crank?
3. The 1g head lookds to be in good condition. Is it 100% neccisary to have the head decked? Or can I clean both the head and block really good and use a new HG with light copper RTV on both sides?
4. The 1g head didnt come with the cam gears. can I use my 95 cam gears? (Remember, i have that stupid cam sensor on the intake cam gear side.)
Also, any tips from you guys that have done the 1g-head swap is helpful!
thanks,
my_gst95
If I remember right, the 6bolt Head studs are slightly wider than the ones used on 7bolts. I just used a set of 7bolt head bolts. (Damn ARP's didn't come in on time :mad: )
It's easier to just wire in a 97-99 Cam Angle Sensor. This is what I did as well.
If you aren't 100% sure both surfaces are perfectly flat, get them decked. You'll regret it if they aren't flat and you put it together anyways.
You can use your cam gears.
http://www.roadraceengineering.com/1g2gheadswaptechtip.htm Read and memorize.
If you have any more questions, either PM me or get a hold of me on AIM! Good Luck!
Awsome thanks. BTW since your offline, Did you really have to make a new bracket for the Igniter assembly to where the position of where it was on the 2g intake manifold, or can I just let hit 'hang'? Also, can I use my 2g EGR or do I have to use the stock 1g egr?
thanks,
my_gst95
If you're using the 1G manifold you'll need its accessories. You can make a coil bracket out of sheet metal easily enough.
I think the waterpipe on a 92-94 is different from a 90-91. I was pulling parts from a late 90 model and everything is as the roadrace and turboawd website indicates...except that on the waterpipe that I got, it doesn't have the nipple that leads to the oil cooler located near the entrance of where the waterpipe meets the water pump. Here you can see that I circled it in blue:
Definetly something important that these sites should know about for people doing the swap. But the 90 waterneck and thermosate seems to be the same as the 92-94's.
my_gst95
