delta448
DSM Wiseman
- 3,627
- 322
- Jan 13, 2006
Waynesburg,
Pennsylvania
You can clamp it to something, back probe the connector, use alligator clips... etc.
WTF
ok im confused.... when you say that in order for your car to run properly.. you have to swap injector plugs too? i mean my 97 eclipse had a 7 bolt with cas that wasn't connected... and i just installed a 6 bolt swap and just switched the spark plug wires... and is running like a champ without touching the injector plugs...!
You don't have a 2Ga CAS or 2Ga ECU, therefore swapping injector plugs doesn't apply to you. The signal from a 1G CAS is the same as the combined CAS and CPS signals from a 2Gb.ok im confused.... when you say that in order for your car to run properly.. you have to swap injector plugs too? i mean my 97 eclipse had a 7 bolt with cas that wasn't connected... and i just installed a 6 bolt swap and just switched the spark plug wires... and is running like a champ without touching the injector plugs...!
did you change the injector firing order at the ecu and did you adjust the BISS screw too so you can raise your idle.
