93 n/a ecu/harness in a 90 turbo car
6 bolt dreams
192
Dec 17, 2007
danielson, Connecticut
ok here it goes, i totaled my 93 mitsu gs 2.0 about a month ago now. i bought a 90 plymoth laser rs fwd roller. i pulled my ecu, and harness which has been runnig a 6 bolt n/a fine now for the year that the gs was still alive. i got every thing installed in the rs it runs and drives fine been driving it for about a week and a half now. i just researched why my tach wont work and apparently in the 91 and up the tach is run off the coil pack, where as the 90s run off some little silver box. i might have missed something there if so let me know if i did. is there away around this so my tach will work??
next issue neither of my windows will work. ive changed the relay for a good one the fuse too. ive tried the switches that came with the car and the switches out of the gs. still they wont work. now i can by that one of the window regs. went but not both. i just got done repining the plug under the center console to match up. behind the pass. side panel there are 3 clips 2 out of the three match up the third one is larger i cant remember if its the car side of the harness or the engine that is larger. which ever it was has 2 more wires on it could this be my window problem??:hmm:
