92 wiring connector identification help
2point3Tsi
225
5
Jan 12, 2007
Maple Valley, Washington
Posting for a friend who's putting a basket case back together. I tried to figure it out side by side with mine but got a little lost, I only have the shop manual for my 95.
These are from the main harness by the maf. [two connector pic]
The other three are by the coolant overflow/frame rail.
That last sad pic is three wires on the same harness as the front 02 sensor.[damage is by cas]
I'll try to get more info what do you need? wire colors? better photos? ect.
you shouldnt realy need help with this, they can only go one place and only have room to make it mostly to that connector that plugs into it the only plugs that are the same is the ac plug and the coil pack plug
Ok, My harness is pretty stripped, but I'll try and help. Not sure what that big one is from off hand (not a maf plug is it? I have an evo 8 on it now, and I thought a stock 1g was more square looking then that), the other one, depending on if it's 2 or 4 pin will either be a headlight plug, or goes to the rad/fans. The triangle one goes to your ignition coils, little round one looks like the o2 sensor, and again the square one if it's 2 or 4 pin, either knock sensor (2 pin) or... can't remember what else was over there, possibly ac or cruise system.
the 3 bare wires I think are the ones that go to the thermostat housing, for the engine temp sensors (2 different connectors on the front of the housing)
I'll poke around some more, but is the big one abs or AC related? I junked my abs last week, but don't remember what connectors were on it, 2 smaller ones I think.. AC was gone when I got the car though, so I wouldn't know it.
I thought the only triangle one in the car was for the coils.
edit. Just went and looked around some. The headlights have 3 pins, reverse switch on the tranny has 2.
Only triangle looking plug I can see is for the coils.
The only other large connector I can see is the power transistor, which doesn't look like that one.
But as I said, my harness is missing a lot of stuff now.
