420A What's this wiring connector?
Cfrakes
63
Jun 6, 2021
Idaho
Messing with the wiring behind the radio and found a random connection. It was wrapped around the wiring leading to the cigarette port. Anybody know what it is? Thanks
That looks like connector B-32 for the power door lock relay. The relay would normally be mounted to the right of the relay seen in your first pick (starter relay I think).
Are you talking about this black box right here? And would the relay be there even if the system doesn't have power locks or would I have to buy one? Thanks
that box is your turn signal flasher unit
I agree based on the connector and what wire colors I see. If you don't have power windows just ignore it - it's an extra unused connector.
See that's the thing. It originally did not have power doors but now it does. Now I just need to get everything plugged in that needs plugged in.
I was talking about the relay down by the blue, black, and white harness connectors. I’m not sure if that relay would be there on a manual lock car.
