ThunderChild
Supporting VIP
- 3,757
- 1,152
- Jan 5, 2012
DEER PARK,
Washington
first off, if this is in the wrong section, i apologize and if it needs to be moved, i would appreciate it mods. thanks.
i recently purchase a 92 talon tsi awd. its in very nice shape, save the front body panels being a lil dingy. it has bent valves from a botch timing belt job (didnt do the BS belt at the same time), so i plan on fixing that and driving the car in stock trim for the time being. it is unmolested and i want to make sure everything works ok before i get crazy with it.
now for the crazy part. ive been doing alot of research on this forum and the internet in general. first thing i did was look up power and drivetrain mods. ive already had a few fast cars, ranging from a built 84 z28 with close to 400whp to an 06 legacy outback XT with around 320whp.
my plan for this car is as follows.
-2.4 liter 6 bolt from a 93 expo mini van
-JE pistons
-eagle rods
-ported cyclone IM
-ported 1g head
-delta regrinds (264's)
-custom FMIC
-2.5" IC piping
-3" GM MAF
-3" turbo back
-either an ACT 2600, 2900 or a PTT twin disc
-welded center diff
-COP conversion
-profec boost controller
-JGS waste gate (if needed)
-Greddy BOV
i will be using megasquirt 2 or 3 (havent decided), running redline fluids for all diffs and tranny, Royal Purple for the motor (after break in) and in general id hope for around 400+ whp. my goal is a fun, reliable daily with some definite balls that will see the drag strip on summer friday nights sometimes.
my questions are aimed at turbo choices mostly. i have the following turbos-
first: the stock 14b, obviously going to be outclassed quickly.
second: a cherry Evo 8 Big 16g 9.8t twin scroll
third: a brand new IHI GM8 RHC61 from a gm diesel (similar to an HX35 and slightly larger than a TO4B)
as you can see by the gist of my mod list, im going for lots of low end tq. i dont want to rev past 7500, nor do i think i will see that very often.
my question is, do i go for the quick spooling, twin-scroll 16g? or go bigger with the GM diesel turbo. both are in equally excellent condition. im not even going to consider the 14b.
the gm turbo would only require a T3 exhaust manifold and external waste gate, and if my calculations are right, full boost would hit around high 3k-low 4k rpms. this turbo is a 350-500hp turbo.
the evo 8 turbo would require an evo manifold and the 180 degree adapter, would spool quickly (almost instantaneously with my setup, id think), still be very efficient and provide great drivability.
i dont want to get a bunch of posts saying "buy this turbo, buy that turbo." i will use one of these two, because i have them already and they were INSANELY good deals, as well as the rest of the parts ive amassed. ive spent at least 5 times what i payed for the car on parts alone, so im not dropping 1k-1500 for a turbo.
id spend less money on the 16g manifold and adapter by about $75 vs the T3 flanged manifold for the gm turbo. im wanting this thing to be reliable, so if i can go with a cast manifold id like too (i can get one for both setups) but i know a tubular will flow better. if i get a cast, i will port it to help. i just hate welding tubulars over and over again.
ill post some pictures soon, i need to get a hosting site or make an album here.
so any help would be appreciated, gimme some opinions. thanks!
-JE pistons
-eagle rods
-ported cyclone IM
-ported 1g head
-custom FMIC
-2.5" IC piping
-3" GM MAF
-3" turbo back
-welded center diff
-COP conversion
-Greddy BOV
