92 GSX Grinding in 2nd and 5th gear
skibumexicano
41
Mar 4, 2004
Johnsburg, Illinois
Hey everyone, I hope you can help me...I just bought my 92 GSX like about a month ago..And it's grinding in 2nd and sometimes 5th gear. If i ease into 2nd it doesn't, but when i slam it into second it does!! I just replaced the Master, Slave and Rejusted the clutch..I would totally appreciate any input..thanks
your synco's could be bad, gears themselves, shift rail etc... do you hear and rattly noises ?
I'd check the Clutch Master Cylinder Brake fluid level, Tranny Fluid level, do a Shift Cable Adjust, put a Slave Cylinder and/or Clutch Master on it ASAP before you destroy the Synchros.
I just put in a new master and slave! It only grinds when it's cold and when i really slam it into gear.
