91 plymouth laser rs-t, this b.... LEAKS !
noxneon
Nov 29, 2010
Washougal, Washington
Hey guys, I just picked up a 91 plymouth laser, turbo with the 4g63.L, and she LEAKS, ALOT. The turbo drain and the oil filter housing are the most obvious leaks, but I've got another leak that seems to puddle in the central crossmember piece, then leak out quite quickly. This leak happens everytime the car is cranked, not just started... I'm thinking it might be the oil pan, but I'm not positive. Any ideas on what could leak that much, is there some hidden oil feed line or something ?
The best thing to do is go to the auto parts store and buy a $HIT ton of degreaser. Hose the engine bay down with it, and give it a good cleaning at a car wash. After that, take some pictures of where the oil starts to form and we can give you some things to look for. Before this though, fix the leaks you know of!
