90 laser 1.8l, lots of spark, no Inj Pulse
war_lord
Sep 11, 2005
Campbell, Missouri
ok I cant get this thing to work....... driving home from work my car just stoped I have fuel psi... lots of spark..... I pulled the fuel rail off cleaned everything hooked everything back up and still nada...... is it my ECM? what tells the injectors to open is it in the dist.? ....... I took the injectors off the rail hooked up the wires and spun the motor over and cant hear any sounds
:laser:
:laser:
do I need to put this in a different thread? :laser:
No, I just didn't see it until you bumped it.
The distribution block tells the spark plugs when to spark.
In order to start your car you need three things mainly.
Fuel
Spark
Compression
Test for spark by pulling the plug wires and grounding them to the frame. Watch for spark. No spark, replace your distributer and rotor.
Test for fuel by cracking a fuel line, holding it in a bucket and cranking the engine. You will see fuel pour into the bucket if your pump is pumping fuel. Your injectors could be clogged also. Take them to get cleaned and balanced.
Test for compression via the www.vfaq.com
the ecu tells the injectors to open. if your injectors aren't opening it is defiantly your ecu which happens to all dsm at some point in time.
I changed the ECM and she runs...... now do I need to clear all the codes off the ecm I just put in or will thay clear them selfs? :laser:
