90 gst burning losts of oil
79magnumgt
Jan 31, 2008
norrisown, Pennsylvania
i have a 90 eclipse gst it is burning a ridiclous amount of oil it is like the head gasket is leaking i have changed it 4 times with 3 different kind of gaskets
the bottom end was bired 40 over decked n i have arp head studs
ring end gaps were all checked n motor runs sound n starts up everytime
makes tons of power
i thought it was maybe the head so sent it out n had it milled n checked n full rebuilt n out it back together with 40 over matching cometic headgasket it is still doing the same thing
the motor is not leaking nething externally n it is not the turbo all shaft paly is good n the front mount does n not have ne oil sitting in it n the piping is all dry
there is oil in all 4 cylinder this is driving me crazy
Valve stem seals maybe? Not a whole lot of places that oil can sneak into the cylinder bores from.
