90 awd talon idle problem
Deli
Jul 30, 2005
Monrovia, Maryland
its odd i havnt had trouble with it before untill i installed a new upper engine bracket the engine will sit around 500 rpm's after warmed up it will sometimes dip below that almost cutting off or it will cut off. i didnt touch any electrical or anything fuel related all i did was remove a busted bracket and replace with a new one.
Thats the side engine mount, but it should not have effected anything that would describe what you are going though, sounds fuel related. Make sure thar you didn't accidently knock the vacum line off the fuel pressure regulator. That could cause a fuel problem like you are having. Its the only thing in that area that could induce that kind of problem. The only other thing is the coil pack put that is unlikely.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
