1G 7 bolt oil pump cover on a 6 bolt
AlexGsxCummins
395
38
May 31, 2014
Bremerton, Washington
So i got a motor from a guy that he has yet to start. I checked the timing and it seems like a 7 bolt oil pump cover is on it because it has the timing mark for the crank behind the tensioner. Am I stuck with ordering a new 6 bolt cover?
That’s a Sonata oil pump which has the crank sensor provision and it bolts on to the 6 bolt block, But for sure, that’s not a 7 bolt oil pump.
The 7 bolt has a curve at the lower section of the case.
Edit - it’s not a Sonata front case, It’s a Mighty Max front case. I just clearing up my mistake for future misleading.
