7 bolt oil pump sprocket
Bedicine
542
189
Jan 3, 2022
Toronto, ON, Canada
Evening.
Wondering if someone could provide me into some insight on the 7 block oil pump sprocket. I just received my engine back from MAP and would like to assemble it this week but just realized I’ve somehow misplaced my oil pump sprocket. I’m going to complete the balance shaft delete in the meantime but is there anyway to put the housing on with the sprocket and instal it after or does the front cover need to be off to install the sprocket so it doesn’t sound ?
Thank you
Thanks, I saw that late last night. He was recommending to tighten it with the belt which a lot of people don’t seam to do and risk damaging it with pliers or vice grips.
Thanks
