6G72 using 4G63 clutch/flywheel
Araesk
188
Jul 10, 2013
Muskego, Wisconsin
As the title states, I'm wondering if I can use the 4G63 7 bolt flywheel and a FWD clutch/pressure plate in a 6G72. I didn't know where else to ask this, and cannot find an answer somewhere else on the internet. From what I've seen they both have similar designs. If anyone has any insight on this it would be greatly appreciated thanks!
The flywheel won't work due to the different number of bolts each uses. Obviously, the 4G63 uses either 6 or 7 bolting it to the crankshaft. The 6G72 uses 8.
The disk itself from a 4G63 will work in a FWD 6G72 application, however.
So my ACT 2600 + PP will work with the factory flywheel then?
I know this is old post but trying to see if you know if the pressure plates well work I have oem clutch for a 4g63, I'm need clutch for my 92 3000gt sohc I was wondering if it would work bc don't have money and just trying to get something to drive
All 3000GT NA cars use the same clutch as the Turbo 4G63 cars.
