-6AN fuel fitting question
oldman
DSM Wiseman
9,789
196
Jun 21, 2003
Dayton, New Jersey
Hello, I've called a lot of vendors and no one seem to have the right answer. I purchase a used set of ss line system that included a earl's inline filter on the feed side. It right now has a -6 AN hose connector at the end inline filter because the person who I bought it from had ran ss lines all the way back to the tank which I don't plan on doing. I'm looking for a connector that has -6AN female (thread) that will accept the -6AN inline filter and connects directly to the stock fuel line connector under the stock fuel filter, I'll be removing the sotck filter. Same story on the return side, it has a AEM silver fpr with a -6AN hose connector at the end. should I just connect a hose to that and the stock copper return line or is there more I should do? Thanks in advance.
oddrob said:
Call Extreme, they have the fitting. 410-672-2700
Thanks anyways but just spoke to them and they don't carry it. They suggested cutting off the the stock copper line fitting and just attach a hose to to it and clamp it down. Is this what people do when they replace the stock filter with a inline filter? Thanks.
Okay, call me at Extreme, sorry about the confusion, it is a special fitting I use in the back, not a normal "for sale item" but I also let Aaron know about it as well. If you still want one...
  • Wanted 6 bolt NT water pipe
    • chrisman287
