-6an tank to rail question
larvaman
31
3
Feb 25, 2010
Port Charlotte, Florida
I am working on a -6an feed setup and am wondering what fitting to use to attach to the factory fuel pump sending unit? The threads are the same as a -6an fitting but it isn't a flare. Will a -6an straight swivel fitting seal up?
if your going to use teflon tape on fuel fittings it should be the yellow tape which is fuel and oil resistant.
That was just a genertic picture, it was raining so I couldn't snap a pic of my unit. Florida weather its been raining twice a day for the last two weeks really hindering the build.
I drilled mine and used a bulkhead fitting like this:
No welding required, I just sealed it with two new aluminum washers (like on an oil drain plug) and a tiny bit of RTV. My tank is still airtight after a couple years of daily summer use.
I speak from experience. I tried it on my 2g gsx and theres not enough room. Not to say it cant be done with alot of modification. But its not worth the time. Full blown pump hangars are nicer looking anyway.
