14mm to 6AN?
nmg72
30
Nov 26, 2012
Mobile, Alabama
I have a 14mm Inv Flare to 6AN adapter. Can that be used on other fuel sending units besides the 2G Eclipse?
No offense but your question is kind of vague. Are you asking if a n/t fuel sending unit is also a 14mm flare, or other cars in general. As far as I can tell, all turbo models have the same size LINE (5/16 I belive) so most likely same flare fittings (14&19mm) but I'd imagine the N/T fuel lines are smaller, not saying they are but most likely.
If you're trying to fix a fuel hanger, if its not to tore up, get a AN fitting welded to it, several others have done this. Also, just curious, where can the adapter you have be found at?
I have the adapter already. However, I decided to put my Eclipse up for sale and no longer need the adapter.
Just curious if it'll fit on other 1995-1999 Mitsubishi since a friend of mine has a 1999 Galant.
I pieced together a fuel line kit and he maybe interested in it since I won't need it.
I got the adapter from 14mmX 1.5 Inv Flare to -6 Flare - Metric Fuel Fitting by Advanced Fuel Injection based on a post from Agentorange313.
