650 injectors with keydiver
erald01
661
Jul 6, 2007
canton, Michigan
i got the keydiver but i noticed on that little paper that jeff sends u with the info u give him when u first order the chip that the injector size was 680. i have 650 on mine but he set it up for 680's...should it really matter?
It should be ok, but you never know. I would log and see if timing is getting pulled when you put them in. A wbo2 sensor would be real be a good idea to make sure its ok. What afr did he set the ecu too?
If you have something to tune with then it should be perfectly fine. I would just add a few % of fuel in there and it should be good.
the thing is that im not gona use an afc or wideband for the keydiver i am gona get thedsmlink soon, but he set the afr 11:1
Jeff burns the chips for the actual tested flow of the injectors, which is not necessarily the same as the rated flow.
Beyond that we can only speculate. Jeff was always very helpful on my order, I'm sure he would make it clear on an email exchange.
