Holset h1 and 650 injectors
Which H1 are you getting? That's a series of Holset turbo, like the HX series. H1C? H1E?
How can you say that when he still hasn't said which turbo. H1 is just a series like I said. H1C is around the size of a T04e, while a H1E is much closer to a T04r.
I have a H1E/HX-40 and up until 3 weeks ago i had 720cc injectors with it.At 22-23 psi and 8100RPM injectors were at about 105-110% IDC. Even if you run the smaller H1C I doubt it that 650's will be enough, unless you run less than 18psi and rev the motor no more than 7K.
I say that because, the 650's wont max out the h1c (smaller of the h series holsets) so it is still an accurate statement. 20 psi is a good guess. ###### cant get that high with the h1e but maybe close.
