spyderdrifter
- 5,426
- 860
- Jul 11, 2009
Somewhere in,
Colorado
First off, I am curious about what follows, but this post is also for reference for others. I have read through some other posts in regard to this, but nothing has been fully clearified.
I know MANY of you in this community have done the 6 bolt swap in some variation. This is now my second DSM to have the swap done, but its the first one Ive started on my own. My last Eclipse had it done prior to me buying the car, so I only learned about what was already there, and not all the research type stuff. This time, as Ive mentioned in other various posts, Im doing it all myself, and learning more about it at the same time. However, Im starting to have an issue with all the available info regarding this. Everywhere Ive read that provides a list of parts required, or optional, states that a 1g main water pipe, 1g thermostat housing, & 1g lower radiator hose are required for this swap
Such as Magnus Motor Sports:
https://docs.google.com/viewer?a=v&...Kt_wVn&sig=AHIEtbQQBwTcYCSRtq3ApdiDkDR7KpauYg
Road Race Engineering:
6 Bolt Motor Install Into a 2G Eclipse
Now that Ive looked even closer at this link for RRE, I noticed it does mention the use of the 2g plumbing, but the others list 1g plumbing only.
I thought about this a little while ago when I was out in the garage tinkering with my setup. I put my 2g head on, and installed all the 2g plumbing. Everything works! Anyone have an idea why 1g plumbing is listed as required? I can see it being required for a 1g head, but not for a 2g head. Here are some pics
From the front:
Here you can clearly see the modified engine mount and 6 bolt water pump, with the 2g pipe in the back:
It all works fine:
Anyone can run the VIN to see it really is a 6 bolt, with 2g plumbing:
Does this setup HAVE to have the 1g plumbing? If so, why? I used to think it was required based on the water pump, but clearly the 2g plumbing works with it just fine.
From the front:
It all works fine:
