ECMlink 6 bolt swap speed density no maf no idle
racersedge1821
103
Aug 19, 2007
Celina, Tennessee
I purchased a 97 eclipse gst with a 6 bolt swap i removed engine and put it in my 95 eagle talon awd. I am having difficulty getting it to idle to even start the tuning process the only way i can get it to idle is with the throttle adjustment screw tightened down quite a bit then i idle pretty high.
I have tried adjusting the biss screw to get the iscposition to around 30 as i adjust the biss the iscposition does not change. How do i lower airflowperrev i know with a maf setup you adjust mafcomp settings.
I am wanting to use narrowband simulation in link i have a aem uego wideband i do not know what to make the switch point to be i do not know which of these options i should use i dont see any specific to a uego wb.
v3narrowbandsim [ECMTuning - wiki]
I do not have a maf or ait sensor installed i have watched all the videos on ecmlinks website just not to helpful with speed density. ive read about every how to on their website. I just emailed them today to get access to their forums.
I appreciate all the help.
