6 bolt swap mount
chasedardis
133
Mar 7, 2010
novelty, Ohio
Im doing a 6 bolt swap on my 2ga and I have a full 6 bolt engine but I have to swap in the 2g mount. I've never done timing before so I want to get all the info before I try. Everything is new so no replacement its balance shaft elimanted. All im doing is the mount swap I've read of a 1 g tensioner tool( do I need it or can I use a long bolt) I just would like some advice on how to go about this to make it easy on myself. Thanks
In addition to what Keiya has provided you, you might check these out.
Helpful links to timing belt tools: http://www.dsmtuners.com/forums/maintenance-repairs/393275-water-pump.html#post152474310
Numerous links to "how-to's" on a 6-bolt engine swap into a 2G: http://www.dsmtuners.com/forums/newbie-forum/383951-6-bolt-engine-2g-car.html#post152352897
+1 (or whatever my rep's worth these days)
Always a wonderful idea to follow up with this when doing a T-Belt job. If you don't have the right tools, you're likely not going to do the job right.
Not a problem! Just pay a little closer attention to the details. ;)
