turbo98eclipse
- 1,096
- 15
- Jul 27, 2004
northern,
New Jersey
Finally got around to testing my 1g black top CAS and get ready to start the car. When I would turn the CAS by hand, nothing would happen, so I went to inspect the wiring. Im using the RRE 1g cas into the 2g harness adapter. When I touched the connector, the fuel pressure would go up and things would seem to work as designed when Id spin the CAS by hand... BUT If I spun it fast enough or just fiddled with it enough, the engine cooling fan would come on. If I tried to crank the engine, the fan would also come on. Any clue what this could be from?
1g cas dsm issue - YouTube
####### Just a quick update:
I checked resistance in the adapter harness & checked voltage at the end of the harness for 5v in the two wires: both checked out good.
Im just concerned why the fan turns on when the cas spins/gets a signal. Are they somehow connected or am I looking at a weird short someplace?
