6 bolt rods in 7 bolt 4g63t.
Mikesam
37
18
Feb 23, 2022
Kennewick, Washington
I have a 7 bolt engine currently in my 2g dsm. I was planning on doing a 6 bolt swap, but the 6 bolt I bought is trash. So I am going to stick with the 7 bolt, but I already bought some eagle h beam rods, and pistons for the 6 bolt. So my question is there a possibility I can use my 7 bolt engine with the 6 bolt rods and pistons setup?
Are your Eagle 6 bolt rods and pistons with 21mm pin or 22mm pin?
There is a way to use 6 bolt rods in a 7 bolt by machining the big and small end width (and the small end diameter in case if you want to use 7 bolt 22mm wrist pin pistons). But I would recommend you to sell your 6 bolt rods/pistons and buy a set of rods/pistons for 7 bolt. That would probably be much easier and maybe even cheaper if considering about the time and money you would spend for that unless you can do that by yourself for free or cheap.
