6 Bolt or 7 Bolt?
vannaksgsx
113
Jul 25, 2007
Boston, Massachusetts
I know it's a 6 Bolt, but what's that "7th" hole for?
(the smallest bolt hole, not threaded)
There is normally a pin in there for the centering of the flywheel. Cranks for the auto's do not have the pin. You might want to look into a machine shop pressing one in for you. I run mine without one, but I am stock. Not sure how it will run with higher power. I just used a drill-bit to center the flywheel, bolted it down and removed the bit.
