6 bolt cams in 7 bolt head
I used my friends old bc272 out of his 1g in my 2g. Didn't have to do a thing but install them, why do you need to drill and tap anything.
It's pretty simple, 97-99's have the cam sensor on the passenger side and the trigger is bolted to the cam. 95-96's have the trigger on the cam gear. Some cams are tapped for the trigger mount bolt, some aren't.
That's cool makes sense ya my friend deffinetly has a 6bolt 1g, but anyway.
1g cams dont have the hole drilled in them to bollt on the 2g style cam sensor the just have a slot so to use 1g cams in a 2g you have to have a hole drilled and tapped for the 2g sensor or use a 1g sensor. Aftermarket cams can be made for both and have the slot and threaded hole already.
