7 bolt cams in 6 bolt head
LarryJoe
376
15
Feb 10, 2012
Davisville, West Virginia
I have someone that's going to sell me a set of 2g HKS 272 cams. Can I use these in my 6 bolt head?
Yes they will bolt in and run just fine.
Just a heads up, if you have the Mitsubishi bible (chiltons book with green 2G on cover) then you would know you could go to engine specs page and it shows all the factory specs of all the differant engines. From DOHC cam turbo all the way to 1.8L NA, it gives specs on bore & stroke, cam lift, all sorts a good stuff.
