SikhDSM
- 25
- Apr 13, 2025
California
Hello everyone, currently have my 6 bolt bare block out getting machined with the builder.
I am specing out a 2.0 long rod combo aiming for at 900-1,000whp, boost peak around 45-46psi, ethanol fuel.
s3 Haltech
Compression: 10:1
85.5 bore
156mm rod length
Epoxy half fill block
Feedback 1:
That being said, the builder recommends stock 6bolt crank will be sufficient (if it checks out inspection) I say other wise. So curious on feedback on experiences running stock crank with high power.
Feedback 2:
Acl OPMB1096 front cover/oil pump is not recommended to be used with high power applications per the stm website. What is everyone running alternatively?
Feedback 3:
O ring vs headgasket? Do many o ring the 6/7 bolt 4g63 block-Or the head? Vs running a Vulcan headgasket?
Question:
Since this block was purchased bare - I am needing to install a cam sensor and crank sensor with housings/sensor/wiring. What do you guys recommend (links greatly appreciated) on setting up these two sensors properly.
Any recommendations and information will be greatly appreciated. If I missed something, please let me know happy to clarify - Thank you in advance.
s3 Haltech
Compression: 10:1
85.5 bore
156mm rod length
Feedback 1:
Feedback 2:
Feedback 3:
Question:
