5'th gear pops out.
b00stedtalon2
1,084
621
Dec 19, 2005
Detroit, Michigan
When I shift into 5'th gear, it will grind a little and then everything will be fine while cruising in 5'th. As soon as I let off the gas it will pop out. I have to hold the shifter with my hand when I let off the gas so it doesn't pop out.
All the other gears are fine. This randomly starting happening after clutch install. Is there something I should adjust?
  • Wanted 6 bolt NT water pipe
    • chrisman287
