Resolved Fuel Filler Neck Plate Bolts - Part Number?
Bland-Biscuit
Supporting Member
339
435
Jul 16, 2019
Michigan
Does anybody have a part number for the 2nd gen Eclipse fuel filller neck bolts noted with a yellow arrow in the photo?
Are these the same bolts that attach the fuel door to the car?
On 2G, those have the same thread pitch and surface finish but different length. The 2 fuel door bolts are M6x1.0x16mm w/ a flat and a spring washer but the 3 bolts you marked yellow are M6x1.0x20mm w/ a flat and a spring washer. On 1G, those 5 bolts are all the same (M6x1.0x16mm).
Thank you. That's very helpful! Any idea on a part number though? I can't seem to find one for the 2g :hmm:
16mm length bolt for the fuel door is MU240097. but it doesn't show the part number for the 20mm length bolt on DSM. MS241191 should be the same bolt.
I ordered one of the MS241191 bolts and compared it to the OE one. They look to be identical. I think you found the original bolt!! Thank you!
I made an article on the Fuel Door components (https://www.dsmtuners.com/threads/533446) to make finding/identifying these parts easier for others, and I thanked you for your help in that section. :thumb:
