50 trim spool time
Chicken Patty
1,446
19
Jun 26, 2007
Miami, Florida
Hello guys,
I'm just wondering where 50 trim owners are hitting full boost at? My car seems to be spooling too soon compared to what I've seen.
I have a journal bearing Garret TO4E 50 trim with bolt on BEP housing ( .55a/r I believe). The back wheel is a stage III T31 Garret wheel. I have a bone stock 7 bolt and it's externally gated with a HAFE cast manifold and TiAl 38mm with .9 bar spring.
I hit 20 psi by about 3100-3200 RPM's in 3rd gear starting from 2500. Is this normal, or too soon? I mean I love it, but it's just weird, looking for feedback from you guys.
The wheels are Garret, stage III back wheel, full Garret unit. Sorry I forgot to specify that. The back housing Is a .55a/r I believe,
Later today I'll see if I can get a video of it so you guys can see it.
At WOT with my 272 Kelfords, and Bullseye 50-trim I see full boost (25 psi) at 3,600-3,800 rpm depending where the rpms are when i give it the beans (usually 2,500-2,800 during tuning).
Dear lord that's fast. I have a sort of 50-trim, the fp3150 from Forced Performance, which uses their 7cm custom mitsu-style housing and a garret ball bearing center cartridge. Boost is at ~22psi, and when the car was running (down right now) I believe I didn't see full boost until ~3800rpm. This was on a stock 2.0l with 264/272 hks cams, with the same wastegate, using an EVC 5 boost controller. I have 2.5" i/c piping with an ugly 180 deg bend out of the ic, and a pretty large Apex-i GTR ic with its bottom row crimped, and I imagine those don't help my situation. I'm very jealous of your boost response!
Fortunately things will change soon as I replace the i/c and install a 2.3l stroker in the next couple weeks.
That is quick spool time I run the same turbo just internally gated. And I don't start building boost till around 3500. Full boost 26psi at 4k or a little later ill have to check my logs.
Sent from my DROID2 GLOBAL using Tapatalk
Yeah guys, I'm seriously impressed, I don't even have cams on yet, they are sitting in my room.
I'll get a video later for sure.
Spooling much better than with the old P-Trim turbine, I see. LOL
Bro, yes. The powerband on the DSM link looks amazing!
Uploading the video now, but here is a pic of just after it hit full boost at around 3300RPM. It was slightly slower than I mentioned above, but still amazing!
