4G64 SOHC 8V Crank Trigger setup needed!
Kyle Koch
Apr 2, 2019
Bossier City, Louisiana
Hello... Newbie here so I am posting in the newb section.
I have a 94 model Mighty Max with the SOHC 8-Valve 4g64. I am learning how to do custom setups and I want to make this engine work before I get into bigger more expensive things in the future.
I am needing a dampener with Crank trigger wheel built in or a bolt on trigger wheel that will work with the stock dampener already on the engine.
For those who are curious or want to know:
I have setup a Haltech Elite 550 in the truck. I have tried using the signals from the stock electronic distributor but am running in to a problem that I believe a crank trigger setup will fix. The problem Is that I can get number 1 and number 4 to spark fire at 0 and 360 degrees however 3 & 2 look like they are firing at 200+ degrees and 550+ degrees respectively. Thus I only have 2 cylinders firing correctly. I am no expert and this could be WAY wrong however the fact remains my engine will not run properly. I did set up a custom Single-Tooth-Home on the camshaft so I will have sequential control later.
Any thoughts, comments or questions welcome. I want to learn this the right way so I don't make expensive bangs in the future. Thanks in advance!
Kyle Koch
I am really sad that after 20+ days no one has chimed in. I was really hoping someone might have some knowledge they would share with me on this.
Please know that I did try searching for the answer before posting the question. I will admit though I am not the best at searching. I never know if I am using the correct search terms to try and find the information I am looking for.
Yes... this is a bump post however I really am looking forward to guidance on this. I do not want to buy expensive parts only to find out they wont work for my application and I lack a lot of knowledge necessary to modify parts correctly to make them work. I am learning as fast as I can but I do not have a budget that supports expensive screw ups.
Thanks in advance for any words of wisdom!
Kyle Koch
