2G 4g63t
2g#gst
Jun 18, 2015
Massillon, Ohio
I have a 99 eclipse spyder gst and about a week ago I started hearing a metal ticking noise comin from my front Driver side tire can also feel it in the brake peddle a little I checked to make sure everything was right and it all is any idea on what it could be?
Wheel bearing hub assembly is only about 2-3 months old and pads look good but will look again cause I did not check for debris but when I did check I didnt see anything could the wheel bearing be making that type of noise? And thanks for the feedback
CV Shaft???
I also have something like that.. Occasionally my brakes will feel like they are grinding and I can feel it in the pedal and I can hear noises like that too. Almost kinda sounds like a spring. Also my anti lock light goes on and off.. No idea what the issue is I just recently replaced rear pads and rotors.
Yes the wheels have been balanced recent I have bought all new brakes rotors and calipers just waiting to have them put on everyone that has checked it out said it has something to do with the brakes so were goin to start there I will let you guys know the outcome thanks for the feedback
