4g63t flywheel troubles
tubbedtalon93
Jul 20, 2012
Macclenny, Florida
I have a 90 talon project. I'm having a problem finding the right flywheel. The flywheel i have is stamped 63dt, but it does not fit in neither my awd or fwd bell-housing. The guy that had it before me had it on the car and it was rubbing the inside of the bell-housing. I don't care is i just get a stock one, i just need to know which one would work.
It all depends on what transmission you are using. Fwd turbo will require a fwd turbo flywheel, awd will require a awd flywheel, and n/t fwd will require a n/t fwd flywheel.
Thanks. I want to use the awd transmission, but i dont know if i can run it with out the rear driveshaft. The one i have is busted. And my fwd tranny is non turbo.
You will not be able to run the awd transmission in fwd mode unless you have a welded center diff or a viscous coupler eliminator. The fwd non turbo transmission would be your best bet, or sell both transmissions and buy the right transmission.
