2G Talon troubles
Boostedmm17
101
4
Feb 6, 2017
Lincolnton, North Carolina
Okay so to start off me and my buddy replaced the bottom end in his 95 talon. Along with that we install a safc. Well we finally have it finished and it runs like dog crap. It idles at 1200-1500rpm, blows smoke and sometimes it backfires. The idle doesn't change if you disconnect the front o2,maf, ECU temp sensor.
So I checked the check engine codes and I got this p0100,p0115,p0110,p0105. Now I don't believe these just up and took a dump. The car only has 48k on everything except the bottom end. So I'm hoping some can chime in on this, because I'm at the end of what i know.
First three codes are probably because you try to run it without the mass air sensor plugged in as all three of those codes are within the mass air sensor. The last code is for engine coolant temperature sensor. If you tried to run the car with this unplugged you will flag that code also. Check the mechanical timing. I hope you're not trying to run a fresh motor on new larger injectors. Would be much easier on the stock system with stock injectors get the motor running then make changes
Okay I wasnt clear. Haha
I cleared the codes after I did that and plugged everything back up before I cleared them. Them they come right back.
The motor isn't a rebuild just a different bottom end that has 100k on it. And everything fuel wise is stock. The only thing upgraded is a big 16g and fmic. But wouldn't the idle or anything change if I disconnected the maf and the o2?
Well it sat since 99 in a field BC the previous owner never changed the oil and had rod nock. And like I said as soon as I clear the codes they come back all together instantly. I checked all the grounds and there good.I'm gonna go back today and take my ECU and temp sensor and see if anything changes.
Oh my friend just reminded me when we first started the car it idled perfect. Then it wouldn't do it again. I'm also gonna take the safc completely off.
So we put a different ecu in and it started right up idles at 750rpm and runs smooth. But we put the original ECU in my car and it ran fine too. So I have no clue. Haha I believe there is a short in the harness so we're gonna take it out and tuck it ECt. Thanks for the suggestions!
