4g63t swap need help
94-eclipse
Nov 24, 2010
Rockford, Illinois
i just bought a 4g63 block 6 bolt with heads and belt but ill replace those. what else do i need 4 the swap
What are you talking about? I'm confused... 4g63's only have one head, and what belt are you talking about?
Typical parts you'll need
-frontcase/oil pump
-water pump
-misc. gaskets
-6bolt oil pan
-turbo exhaust mani.
-turbo
etc.....
turbo, oil and water lines, turbo water pipe, turbo oil filter housing, intercooler and pipes, turbo ecu, turbo injectors, boost and air fuel gauge, turbo 02 housing, turbo downpipe, turbo intake manifold, turbo fuel pressure regulator, better fuel pump, knock sensor, turbo exhaust mani... etc. etc..... search!
Please elaborate to make this easier and more precise for both you and us.
I imagine you have a non turbo as per the info on your profile etc. But do you have a 4G63 non turbo or the 1.8l? If you have the 1.8l I suggest you keep it as a dd and find a clean shell to swap the 4G63T...
If not, GrattinoDSM and GsXdSmKingGsX pretty much answered your question.
Also, please use punctuation and capital letters so we can understand what your trying to ask. Thanks and good luck!
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
