4g63 water coming out of the head into turbo
4g63love24
Aug 6, 2013
Greeley, Colorado
Im not sure if im in the right fourem but here it goes i have a 4g63 thas been spilling water from the head into the turbo i just replace the head gasket thinking it was that ### my old 1 was pretty bad but its still doing the same and i have no idea what can iy be can somebody ### help
Either your head or block is warped and not allowing the gasket to seal or one of them is cracked. You should pull the head back off and take it to a machine shop to have them check for warpage and check for cracks. If your head turns out to be fine, it has to be a problem with your block.
