4g63 to 4g63
hondasuxs
Aug 21, 2006
colorado springs, Colorado
i just wanted to know if the 4g63 motor is the same as the 4g63t besides the turbo are all the interal parts the same? tranny flywheel rods etc?:confused: cause i want to swap my motor to a 46g3t but the 4g63 is way cheaper with out the turbo so maybe i can just get the 4g63 and swap exaust and intake manifold and drop the turbo in there please help
thanks timothy
there are quite a few differences in the engines, like youve allready stated the exhaust manifold needs to be changed, the turbo , the nt 4g63 has 240cc injectors where as the turbo 4g63 has 450cc's, the compression ratios are different the turbo model is 7.8:1 where as the nt is 9:1 i believe and are much weaker compared to the turbo internals . There is also a knock sensor on the turbo engine.
All in all you cannot just put the turbo on the engine.
here is the link that explains it all.
http://www.dsmtuners.com/forums/showthread.php?t=5986
thanks man that gave me a lot of knowledge on the two motors they are really different but at least i can still turbo the n/t motor for cheap
