4g63 n/t from laser going in to 95 gst please help
JadeGreenWright
Sep 24, 2006
glenpool, Oklahoma
ive search and searched and i cant find nothing my 95 gst block is blown and im looking to swap it with a 4g63 n/t out of a 94 laser but planing on keeping the the head and intake from the gst will this work and what all do i need?
There aren't any oil squirters, it shouldn't be much work though. You should just find a 1g turbo block, they are easy to find on here even, and for just a shortblock, not real expensive.
i already have the laser i bought it for 75 bucks thats why im doing it like this i know there are no oil squirters and the motor mounts are slitly diffrent but i want to know if it is possible i know i will need a oil pan from a turbo motor due to the oil return line on the turbo but my main consern will it all fit up if i use my 2g head will i have still have to worry about the cas and will it bolt up to my gst tranny?
Yes it will work. You still have to have the cam angle sensor to make up for your crank angle sensor not being there all the the 4g63 bellhousing bolt patterns are the same so your tranny will also bolt up. I have done one of these swaps and it worked fine .
ok will i still have to do all that drilling and caping that roadrace site was talking about? or can i use most of the 1g parts?
