from N/T to T
j-jamrod
83
Nov 8, 2007
Baltimore, Maryland
Yes as the tread say i have a 1993 eclipse N/T, but i want make the conversion to Turbo set up, , the question is, do you guys think is nesesary to replace the wire harness? i have the turbo ECU , the turbo engine, that only . the question thank you
No you don't have to swap out the entire harness. Just run the 3 or 4 wires and wire in the resistor pack and call it a day. Alot less time and you will get the exact same result.
