4g63 n/t compression ratio's?
buhay6
1,661
65
Jul 9, 2010
Delisle, SK, Canada
I've looked back for past topics that cover a 4g63 n/t good compression/low compression ratio's and found nothing but answers for turbo'd 4g63's (very widely covered topic), I know they use different pistons so the compression ratio's are of course not going to be the same.
So here's my cylinder compression ratio's:
1 - 147psi (tranny side)
2 - 140psi
3 - 135psi
4 - 149psi (timing belt side)
Car doesn't seem to be burning coolant and its definitely not burning oil, plus it sounds like it runs strong. These numbers good or getting to the low side?
Finally got my parts from DSM grave yard i ordered over a month ago so I don't wanna waste them if I'm going to need a rebuild soon.
turns out it forgot to push the throttle pedal down, and the engine was cold. I re did the test and it came back at
1- 156
2- 154
3- 127
4- 141
So with those revised numbers I'm actually thinking my head gaskets gone of the heads warped because I filled it with coolant and hadn't run it in litterly 3 weeks and the coolant levels not full anymore.
