4G63 - JDM motor with nothing but problems - HELP! (PICS)
crazyz250
Aug 26, 2005
niskayuna, New York
Please read and Please help!
Okay heres the scoop. I have a 93 Laser n/a. It ran great but around 90k it aquired a rod knock. I purchased a 6-bolt JDM block/head/5-speed from a reputable site trough ebay. Block had between 35-45k and had 6 month warranty. I will list what it was advertised to fit once i find the papers tonight, but i e-mailed the seller and asked "will it fit a 93 laser?" and he said yes
I then pulled the motor
and started swaping the accesories from one motor to the next - replacting gaskets, claning this, fixing that. New motor was Pretty clean all around
Well the motor was ready to be put in:
Instantly had problems. First off, from the exterior, there were noticable differences from the two transmissions (I replaced mine because it grinded first and second) Everything bolted up as it sohould, but the lines on the outside of the case were different, and it had a few different mounting points that the orginal one did not. Upon mounting the motor, we soon realized that it was not going to happen. With the right side, front, and back mounts in place (tranny mount not bolted up) the motor looked like this:
The hood would not shut, the IM hit the bottom of it.
This is how far off the tranny mount was:
Look how far off the bolts are from the holes in the frame. We managed to get all 4 mounts bolted up, but it vibrated soooo bad, and the right was puched forward and the left was ushed back, deff not right.
(we have since welded the mount where we wanted it)
I used the OEM mounts that were on the orginal motor. Everything else bolted up just fine.
WHY???????? Anyone know????????? :cry:
- Upon starting the motor once it was "semi" bolted in, we ran into problems. It was my mistake to not replace the water pump before the motor was put in. The gasket was rock hard and leaking. After replacing that, the oil pressure guage was going crazy. We traced that to a faulty sensor and fixed that. The cam seals were leaking, so we changed them out aswell. They to were rock hard (a sign the motor had been sitting around for awile) Both cam gears were wobbling, and one even broke (while motor was not running thank god) i simple pushed it to see if it was loose, and it broke! There were about 10-15 other probles we ran into, but i cant remember them all there were so many LOL.
- a 1G DSM is one hell of a good looking car - so why not fix it up ehh?
$1,200 maaco paint job - OEM green paint with added gold flakes - came out VERY good, people comment me on it all the time, very clean - i got lucky:p
- Car was in storage from november to april - gota love NY weather
- Okay back to the problems - because this car has lots of them. So once we got it running for the summer, we instantly had problems! What else is new? New radiator was in need. Put that in and it was still burning/leaking antifreeze. I couldnt find where it was going, it didnt drip on the ground, but was eating about 1/2 a quart ever 100 miles. It ran OKAY, and i didnt see any white smoke. IM gasket was new and pluges looked fine. After giving up i brought it to the stealership and they did a complete leakdown test. Turns out i have good compression, and my head gasket was good (to my amazement) Once the cooling system buit up pressure, there was a pin hole leak under the thermostat housing, and once it hit the block it would burn it - thus leaking antifreeze w/o driping on the ground. Well that was fixed and i know i have a solid motor., and also know im an idiot for not seeing that:(
- The orginal motor mount job HAD to change - so we did the fallowing:
We bolted the right side mount with a new poly mount. We then leveled the motor, centered it in the bay and welded thet f*&#er to the frame
We have the front mount bolted up, trany mount welded, and right mount bolted up. Problem solved ehh? wrong. Vibrates like a bi***!!!!! i figured it would, but not this much :barf:
- My power steering pump then shit the bed
- Okay long thread, but theres alot to this car. Here are the questions:
1. When starting car, it idles right at 1000 rpm's. Isn't it supposed to go to like 1500 then 1400 then 1300 etc. until it warms up? When warmed it idles just about 1000rpm
2. Why does the idle fluctuate? crusing at 50mph in 5th and push in the clutch it will drop to about 500, almost stall sometimes, then go to 1000. Sometimes randomly go up to 1200? wtf?
3. Motor mounts not working....
4. No power!!!! Seems to me that it is low on power, when you punch it the balls that is once had have shrunken severely. When reved in upwards of 5500-6500 rpm it just seems like it doesnt do anything but make noise
I searched around a little bit and have found the only difference in the JDM vs. USDM is the IM. I only bought the block/head so i should have no differences correct?
ANY insight to why my motor is not running correct, and doesnt fit my car LOL would be great - i am at a loss at this point and so is the dealership - they are stumped Thanks!
Does your car ever overheat?
btw what size are your rims?
-Frank
Yeah we did have problems in the past with that. We have sence replaced the thermostat and radiator and it has been fine
The rims are ADR 17x7 im not sure what style - yes i know the car needs to be lowered LOL
I would redo the compression test on a warm engine at WOT with all plugs removed.
Okay i will try that tonight and see what comes up
can anyone tell me what the tranny number means???
A14
420151
Thanks guys you know way more about these cars then i do!
To do a simple a quick compression test, get the car warm and up to temp. Pull the mpi fuse. Screw down the tester and put our foot all the way down on the throttle and turn the key for about 10 secs. DONE!
James :laser::talon:
Man, it does apear to be a turbo motor from what you've said and from what i've seen guys like that ship out, i can almosta garauntee you that it is. As soon as you put "reputable" and "ebay" in the same sentence you jinxed yourself.
Don't know much about the working of the NT cars (or the ECU's for them) But i did want to say that you've got a nice looking 1g even if it is N/A. I wish i could count on a Maaco paint job to come out that decent!
yeah tell me about it, im so pissed this isnt even my car - i sold it to my uncle and he said if i did the work he would pay for everything - well hes broke and we have a messed up car and its up to me to fix it:notgood:
So basically i can either turbo the car or swap a different motor in but the way it is rite now its never going to run good correct? Does ANYONE know anything about my tranny code? I didn't have a chance to do the compression test tonight but its pretty obvious i have a turbo block:beatentodeath::beatentodeath::beatentodeath:
Thanks for the comments on the clean car. It has been well kept over the years and it certenly shows - driven every winter in the northeast to. The paint came out very good and my rookie body work came out pretty good i must say. Here are a few more pics of the car:
WHAT SHOULD I DO!!!!!!!!!!!!!!!!!!!!
- Call the place i bought the motor from - bi*** and bi*** and bi*** until i get the right motor????
- Not looking to turbo it - it has enough problems as it is
- Drive the car off a clif?
Someone PLEASE give me some ideas on what to do, im totally stumped and very very pissed
Blow the car up and report it stolen =)... j/k I would contact the seller and see what they have to say but chances are they will tell you all sales were final. See if you can message anyone on ebay who has also purchased the same motor from this company and find out if they ran into any problems.
Well i delt with these people before - The tranny grinded in a few gears, and after some talking they gave me half back on the tranny - $150 They seemed helpful and they insisted they would do the right thing. All i want is the right motor, maybe if i do it right i can get the right motor out of them hmm.... i need proof like using numbers from the tranny/motor that its the wrong one
sure does, maybe thats why it has problems? haha j/k but i guess they use these motors in hyundai's in japan?
Can anyone tell me what these numbers mean? turbo/ or n/a tranny? are they the right numbers?
A14
420151
A14
420151
Look again, it should be stamped on it.
I will find the tranny number tonight - what should it look like? F5M33 or F5M31?
I will do a compression test on a warm motor at WOT tonight
-Morphius thanks for the help, im going to need answers to a bunch of questions about both motors before i call this place up, i have prof from the dealership on their compression test/leak down test stating everythign was ok and i only put about 500 miles on this motor.
"Last year we sold over 400 engines on eBay alone. Our 100% positive feedback and reputation are built on our commitment to your satisfaction"
Oh really?
I'm getting the right motor from these bastards one way or another.
Besides the initial location, you can look in the other places I circled here. I know it's stamped on the case.
- I called the dealer back to find out what their compression numbers were because they never told me, other then i had good numbes all across.
cylinder 1 - 180
cylinder 2 - 180
cylinder 3 - 170
cylinder 4 - 175
What is a n/a motor supposed to run at?
What is a turbo motor supposed to run at?
i am heading home at 230 to find out the number on the tranny and the number on the block - couldn't that tell me what motor i have?
engin block code - G40P 72652
is 180 compression n/a or turbo block?
I couldnt find anything else on the tranny wtf?
Hmmm so the block code says i have a n/t block and im still not sure about the tranny i dont think anyone knows what those numbers mean. This sucks.
So whats wrong with a turbo block running on a n/a ECU? is it going to hurt anything? need some help here im lost
