fmic install nothing but trouble any help?
mheidemanjr
203
Jun 7, 2009
medina, New York
ok so i got a ss auto chrome fmic got it all hooked up the intercooler lines keep blowing of got that fixed now it just runs like straight s$#t. only get like 5psi on my boost gauge but the stock one reads max? any ideas why? allso it buks real hard around 4k rpms , feels like it just dies then kicks back in and the a/f goes full lean? could all this be boost leak? where does the stock boost gauge get its boost sourse from and why would it read max when my after market reads like 5-9psi 9 being 5k rpms? any help would be great as my wifes pt crapper just blew the f$#king head gaket so now its gotta be the dd till i get her something new thanks guys
:ohdamn::ohdamn::ohdamn::ohdamn: :confused::confused::confused::confused:
sounds like a hella boost leak. Make yourself a tester and find that leak. My .02 on the pipes, I had beads rolled on all mine 20$+ I put a small hit of some glue on each coupling as I joined them up. FIND THAT BOOST LEAK :thumb: and its prob solved. I would throw a new h/g on that PT its just a 420a.
Definitely a boost leak, think about it, what else could it be? You installed a fmic, now you're getting fuel cut, low psi on boost gauge, and car running like crap.
The stock boost gauge gets it's reading from the mas, which reads how much air goes in, even though you have a boost leak the turbo will still pull lots of air in through the mas, causing a false reading on the stock gauge.
allso it buks real hard around 4k rpms , feels like it just dies then kicks back in and the a/f goes full lean? could all this be boost leak? this could allso be boost leak? it ony buks one time every gear at 4500 rpm?
+1 on def doing a leak test so you can see exactly where it is coming from in case so you know what to pay special attention to if you have to take it apart again.
Yeah but its by no means a set it and forget it operation. JB weld is not metal and it does it melt and form into metal FULLY eliminating the hole. You are in essence putting a plug on it. ANY local welding shop will throw a bead on it for 20 bones or less.
