4g63 block question
partyplace69
Nov 6, 2005
springfield, Tennessee
i have a stupid question but i am going to ask it anyways. I know that both turbo or na heads are the same but the cams are different. I was wondering if the blocks are the same? 6 bolt
The blocks are the same, yes, but with some differences.
Difference in turbo and N/A blocks is N/A blocks do not have oil squirters stock. There is no knock sensor, the compression is 9:1 whereas turbo 1g is 7.8:1 CR. Also the non turbo crank does not have the crank center dowel pin on the flywheel side of the crank.
