Jeff99GS
- 1,870
- 17
- Jun 27, 2006
Cleveland,
Ohio
I want to purchase a 60mm throttle body for my Non turbo eclipse. I see one made by Modern Performance, its' a billet 60mm TB with half shaft. Has anyone else used this Throttle Body? I want to know if it is any good. Is 60mm the largest size TB you can get for the NT?
so I need all the help I can get in the spool up department
. You need all kinds of help. If it isn't too late, get your money back for the ignition wires. Those should only be something to consider once you're at the point that you need to eek out another 1/8hp because you're already at 1,000hp.
