400whp
91gsexx
Apr 7, 2013
Statesville, North Carolina
Wanting to make 400 on pump have 750cc injectors 255 what turbo to go with want to try to stay stock manifold what turbo should I run
If you have sufficient funds then a fp 71hta will be good for you. Little bit pricey but you pay for quality. Or you can buy a 20g like he mentioned above. Much cheaper ofcourse.
Thanks guys I think that's what I'll go with and grab a set of dgy (dsm graveyard) 272s and dsm link 3.0
Looking to make the same out of my 90 gsx. Will probably go with a 20g with a similar setup too. Should be a nice little street machine.
I seriously doubt your going to make 400whp on a 20g on straight pump gas. Not to come in here and be a thorn in your side, but unless you have a great setup with a very good tune, 400whp on pump with a bolt on 20g more then likely isn't gonna happen. It's not as easy as just simply bolting a couple parts on the car, making a few changes in DSMLink and BAM 400hp. I just don't want to you see a thread 2 months from now saying I went to the dyno and only made 320whp what's going on? You know?
+1
you need a bigger turbo to meet your 400 hp goal. It can be done but whats the point? Youll have so much rapped up in toys when u could have got a bigger turbo in the first place.
That is my goal as well. I am currently running an Evo3 and have seen at best about 310hp. I think once I switch to link and upgrade my fuel I can get to 325 or so on pump. I'd explore the 20G route too, but only if it is a true TD06H model, as I don't think there is a superior Td05H turbo then the E3.
I've considered the Green and a small Holset too, but I kind of like the old school all "factory" draw of a MHI 20G.
I'm looking at a similar number as you. Currently looking to pick up either an FP Green or a TD06 20g. Just remember that you will need supporting mods to run those turbos.
