400whp setup?
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
So I'm in the process of building my car and I need some advice with the turbo setup for 400whp.
e316g or 18g or ?
FP Race Manifold, I'd have it ceramic coated
2.5-3'' downpipe
evo3 o2 housing, ported
basically I want a good turbo for street only and able to hit about 400whp.
I'm open to suggestions
i would look into getting something a little bigger. although you can get to 400 with the 16g it would have to be a pretty aggressive setup and probably not well suited for a DD. 50 trims are usually very good on pump gas and should be able to put u were your trying to get without to many problems as long as you've got all other supporting mods.
im aiming for the same thing you are, but im going with the holset to see how that works out
Not from personal experience but from alot of forum searching. I think your better off going with something bigger for a turbo. With alot of mods and some epic tuning may be able to push that Evo 3 to 400 but I doubt it.
A 20g would suit your needs if you're trying to stay with a mitsubishi turbo.
My buddy is making 400whp on his Frankenstein 20g no problem.
Otherwise maybe consider going with an HX35, would get you there easily too.
