4" downpipe on a bottom mount manifold?
slowgsr
862
10
Dec 17, 2007
hamilton, ON, Canada
Well, I just quickly made up this downpipe yesterday because I was bored. Its NOT welded yet, since incase I have to 'tweak' the bottom bend that goes under the pan to fit the rest of my exhaust easily I will be able too. However, It should be fairly close.
Well, I had to use some 'cheater' bends, Since I am using a bottom mount, I didn't have room to get the full radius 4" bend in there.
The car has a full 4" exhaust with no muffler, its very straight and very 'un-restrictive'. Im just worried that the sharp bend coming off the turbo is going to cause too much restriction?
I don't really think it will be an issue since the rest of the system is a very free flowing 4", and it is afterall 4" turbo-back? What do you guys think. I mean there isn't really much I can do about it, but if it may be a big concern, I could put a backpressure sensor in the downpipe to make sure its OK.
I must say, that 4" stainless is hard on my bandsaw blade! Don't mind the vice grips, I only had 1 bolt kicking around and had to improvise.
It looks great. This is how I roll.
I'm not sure, if anything I will wrap it. It's all 304 stainless.
Great work, Eric. That's some excellent pipe fitting there.
Don't worry about it being too restrictive. I've seen much worse from cars that performed very well, so I think you'll be just fine. I can honestly say that I would completely trust running that on my own car. I know some of the turbine outlet bends have very sharp, less than desirable angles, but you've done a good job at utilizing the space that you have to make it the least restrictive as possible.
Thanks, Ill get some finished pics on here and update the thread once its all welded up and connected with the rest of the exhaust, on the vehicle etc.
Heres a couple of 'finished' pics.. I Just have to have the vband welded to the aluminum, but thats all gravy.
The waterpipe DOES fit.. However, I will not be using a factory full length waterpipe, since im moving the outlet on the rad to the lower drivers side rather then the lower passenger side.
I had to 'modify' the dipstick, but its done, it was a huge pain! However, The dumptube(s) will dump right infront of the downpipe between it, and the crossmember, so I needed some space there.
I also plan to add a before the flex under the pan somwhere to help support the downpipe, 4" stainless is damn heavy
I don't really think it will be an issue since the rest of the system is a very free flowing 4", and it is afterall 4" turbo-back? What do you guys think. I mean there isn't really much I can do about it, but if it may be a big concern, I could put a backpressure sensor in the downpipe to make sure its OK..
It looks great! This is one of the most non restrictive 4" exhausts Ive seen. Looks like your doing a great job, keep it up! :thumb:
Got to love those forward facing oil filters!
this is my 4" exhaust
Yours looks like its a 3" to 4". His is a straight 4". Its nice, but doesn't really compare.
how does mine not compare? It's 3" for about 3 inches. The exhaust is moving so fast at that point it's not restrictive.
Here is my 3 inch 409 SS downpipe. Do you guys think its going to be a problem by the oil filter? Dont look at the welds please.
I'll get some pics up tonight, it's all tig'd up and been installed.
It looks like 3" pipe for a bit more than 3 inches. The whole problem with the 4" was the bend right off the turbo. The OP did a great job with the bend and the whole exhaust. 3" tubing is a bit easier to make the bend. Im not saying yours looks bad, I like it, its just easier to make the bend rather than the 4" pie cut. Or just 4" in general.
I like your return line, did you weld the -12an (assuming) on to the pan?
Stainless down pipe to aluminum exhaust? Looks good, I like. :thumb:
if my turbo had a 4" exit i could have use a tight radius 4" 140* bend that would have been easy. i mocked it up on my hx55 but for now im running the hx40. and yes thats a 12an drain line with a welded bung in the pan.
